Brief Description: Installing the Surfaces to the Main Shaft
Had to do some minor adjustments to the bushing set up. Modified some standard washers on the lathe to fit the plans and its job. Studied the plans and tried to position the shaft clamps and the drive clamp in the right angle onto the main shaft.
In the evening I had to primer and spray one of the clamps- for some unknown reasons, this piece was not done yet.
